I say points for your triples Paul, ( you ) have great store in the simplicity, can see the attraction, i have/had ( since removed for iis 2 stroke system ) points on a triple water cooled stroker, the attraction of points when working has you attracted, meets your needs, ( i, the only perpendicular pronoun ) had the option of no points and took it.
Your championing of points is laudable, i like them also as an historic mechanical electrical wonder as they spark away, engine humming along, tactile feel you could say, without touching, maintenance time, very touching then. Best of both worlds for you, though you omit what is running on your triples? You ride them, you fix them, you make choices... the bone pointing is of some bemusement here, bless the postings. j.
