Stu
- South Wales, UK
I am trying to fit a reconditioned crank but I think that I may have a problem. The half ring (a snug fit in the crankcase) that locates the outer bearing on the starter side is narrower than the groove in the bearing, which would potentially allow a small sideways movement of the crank. Everything fits nicely when its over to the drive side but pushed the other way the oil thrower on the drive side is very close to the web for the centre bearing. Also the outer race of the drive side roller bearing is about 1mm away from the half ring on that side. Is this normal or should the outer bearings be shimmed?
