My 750 SF has decided to shear planetary gears. I have replaced the the broken one and it has happened again
Has anyone had a similar experience or know what might be causing this problems?
Any help would be appreciated.
If it is like a car dif they need to engage teeth in a particular way and depth. They shim them and check engagement with engineers blue on the teeth. That's all I got, no other clue from me.
Have you dismantled and cleaned it thoroughly and checked that there isn't something getting in between the teeth? Is it from the same post that has the broken gear? Is the gear on the starter motor itself in good condition?
