750 SF1 fork cap leak
Rob
Midlands, UK
Before I pull the forks apart to see what's going on, can any knowledgeable 750 fans tell me if there should be a small hole in the fork leg caps?  And if so, what stops fork oil lightly spraying out?
TIA
Hi Rob.
That hole is supposed to be there. It goes to just above the pressure relief ball (which is held down by a spring, under the slotted screw). The hole is the air exit point.
It shouldn't give out oil though.... Take the slotted screw out and see if you have the spring and ball in place. If they are not there, air and oil mist/creep will be transferring via that little hole every time the forks move.
The idea behind the ball valve is that when the forks compress hard, a little bit of air is pushed past the ball and so a small under pressure is maintained in the fork, thus helping the seals keep the oil in. During normal fork movement, in a bimble around, there should be no air/oil getting past the valve.
HTH Paul
Paul... many thanks. Will do as you suggest. I'm an expert with balls, having dropped and lost the 8mm one out of the clutch operating arm mech ::)
I learned a new word last night "amazeballs"
I young lad of eighteen, currently working for my son, Tom, was being shown TOG in my workshop and being told about its use and history by him, I was earwigging at the bench, and adding in a few bits, in addition to the word "like" being interjected more times than McSock uses the word normally associated with fornicating, his description of small and custom altered parts to suit me, was usually "amazeballs"
Did you?
CLEMTOG said:
In addition to the word "like" being interjected more times than McSock uses the word normally associated with fornicating,...
I've already explained this to you, Clem.
    ing (word removed to protect the sensibilities of the sort of    (word removed to protect the sensibilities of those who complain to Moderators about being "offended) who complain to Moderators about being "offended), in Scotland, indicates that a noun will be along shortly.
Crikey - dunno what you lot are drinking, but you shouldn't!
OK - just to be boring.  Looks like I'm missing one ball.  :-[  Anyone know the diameter of the pressure relief ball please?
I just measured mine that were jammed stuck- 4mm
