NeilD
- on the road to Skegvegas, Lincs
well, i had to push the bike most of the way home tonight...
fortunately i hadnt gone very far!
anyway, symptoms as follows..
ever since i've had it, on occasion it would feel really 'flat' when first started - not missfiring, running on both cylinders, but relucant to pull above 4000 rpm... whenever it did this it usually cleared within a mile or so of leaving home.
Tonight it didnt and after filling with fuel it wouldnt start. didnt have many tools with me but pulled the points cover off and the points didnt appear to have closed up and were sparking when opened with a screwdriver.
Eventually started and headed back home, still as flat as a witches appendage.. then it would just stop dead.. i'd push for a while, it would restart then die again after a few mins.
so... i'm assuming electrical as both cylinders appear affected in equal measure concurrently.. the general lack of go is making suspect timing, and a quick search on here shows the A/R unit as a common problem...
is it likely to be anything else that would affect both cylinders? I'm just in the process of getting my Ducati on the road so am tempted to sort that out and leave the SF and eventually go for one of the electronic ignitions.. the bike is due a good look over as since i've had it all i've done is put petrol in it, check the oil and tyres and ride it.. :-[
Neil
Neil
