TeddyG
- Portland Oregon
While sorting out a 74 750SF, I’ve learned the following: (some are stateside suppliers)
Bevel Heaven in CA offers full Dell Orto parts and servicing
Venhill can make any cable or hydraulic line
Honda 750 exhaust gaskets fit and valve cover gaskets and dynamo pulley are available from industrial suppliers like Graingers
Bultaco East sells NGK B8ES plugs and caps and Dennis Kirk sells similar Champion N2C
DAM Classic Racing sells a great oil sump cover w magnetic drain bolt
Sylvania LED headlight bulb w/ resistor from Auto Zone works well w no flicker
NAPA sells LED tail light
DNA pod air filters fit w snorkels from OEM air box
Ton's Performance sells Packard 440 copper core spark plug wire
To keep the throttle and choke cables from popping out of the carb mounts I zip tied the cable splitters to the frame and dual throttle cables might work better
Carbtune makes a quality dual carb syncher
