My 750GT came with VHB29 carbs with the following internals.
Pilot Jet 55
Main Jet 175
Atomizer 265N
Needle V3
I have ultrasonically cleaned them but cannot get the bike to run right. (not sure if it ever run on these carbs as off road since 2014)
I can set it up to start easily and tickover fine but once off choke it will not pick up under load and just misfires, if I put a bit of choke on the bike picks up and runs much better and rides fine when cold and on choke. All ignition is good,
With the above settings I would have expected it to run rich not be fuel staved.
I understand the book settings are
Pilot Jet 50
Main jet 112
Atomizer 256N
Needle V2
Before just going back to factory settings anything else I should check which would mean the current internals were used or are there any recommended changes.
Thanks
Pilot Jet 55
Main Jet 175
Atomizer 265N
Needle V3
Pilot Jet 50
Main jet 112
Atomizer 256N
Needle V2
Thanks
