TeddyG
- Portland Oregon
Well, after chasing down several possibilities for the poor engine performance and excessive vibration of my 750SF, I finally took heed of advice given by Forum members, and I removed the cam cover (after tilting the motor). With the TDC marks aligned on the engine case, there is no mark visible on either side of the cam gear. But further down a few teeth, the master link is visible with no doubt the timing mark. What could've caused this- a loose timing chain or poor work when the engine was supposedly rebuilt previously?
So my question is how to advance the timing just on the cam gear, while keeping the timing aligned on the engine case. With 15K miles on the odometer, I'm assuming a new timing chain is in order.
Next will be removing the cylinder after seeing excessive wear using a boroscope.
