750SF1 Starter Noises
That sound is perfectly normal in a starter that needs urgent maintenance 🤣
Lots of threads on here about starters and the sprag clutch, worth spending some time reading 👍 The sprag springs and rollers in particular seem to need replacing long before you notice any problems, and a strong battery is important too.
And, the starter clutch is considered a maintenance item. It should be periodically removed, cleaned and lubricated. By the time it starts making bad noises, you will need to replace parts.
