750SF2 head case
mikeb
new zealand
A couple of questions re head repairs.
1. The camshaft tunnels are a bit scored and one or two bearings have spun a bit (see pics). I’m thinking Loctite 609 on the cam/bearings and 641 (weaker) on the scoured tunnel…. Yes? Better ideas? all bearings are being replaced - there was a slight rough patch on 1 or 2 of them
2. I’ve read about cutting the cam key in half to aid reassembly. Sounds good, as I imagine a key in place in each half will greatly assist pressing the flanges back on accurately. As the bolts do the work, is there any downside to cutting the key in half?
3. The valve seats are slightly pitted but I think look ok (see pics). Am I right that they look like a PO has replaced them? ie, they look like inserts, not 'skulls' (not that i know what a skull looks like). The valves are 7mm and look farily new to my untrained eye, and the contact / wear ring less than 2mm (tho hard to measure accurately).
Thanks!
7mm? Looks like you've got a nice pair of SFC valves there. Std SF are 8mm stems, and that penny on a stick exhaust looks def to be SFC. Check your cam for a number - you might find it's been replaced with maybe a 5/C - std SF2 will be stamped 7/1. Owners generally wouldn't fit 7mm stem valves to an otherwise stock motor.
Check that the old bearings were C3 (larger clearance) - it's be marked. If not, buy new ones in C3. Generally I wouldn't be too bothered about them spinning a tad (you'll probably find your crank bearings have all been doing a bit of dosey do!), but a std clearance bearing might have more tendency than a C3. I've never Loctited them - you definitely wont' need to Loctite the bearing onto the cam - it's a decent press fit (hence the need for C3s).
They do look like inserts - I can see both cast skull and the insert. Not a bad thing. Give the valves a light lap with paste and those pits should disappear.
It's not tricky getting the two halves in with the full key, but not a prob to cut it. Personally I wouldn't, unless I intended to check and dial in the cam timing. If you know how, it can be very worthwhile - and left to right may not be the same either. To make them adjustable you'll need to slot the three holes in each flange. If you're not trying to get every last HP out of it it may not be worth the trouble - and cutting the key will potentially introduce discrepancies between L and R that may not have otherwise been there.
Thanks!
7mm valve stems?
What cam is in there?
Where did you read about cutting the cam key in half to align the flanges on reassembly?
The cam bearings are actually quite free to move around a bit. Even the slightest warming of the head allows the bearings to slide in easily, when at operating temperature, the bearings will be even looser. Loctite is not recommended. The camshaft assembly is located by the cam end caps, axial movement is limited.
No problem at all cutting the key, been doing that for years to aid assembly. I actually use 2 short keys, looks neater. ;) Far more important is the interferance fit of the flanges on the camshaft! This should be at least 0.01-0.02mm, otherwise the key/s won't last very long. Also make sure the flange and sprocket mating surfaces are dead flat to ensure adequate clamping pressure.
The seats indeed look like inserts and as thus, are probably of far better quality and hardness than the originals cut into the cast iron of the skull. Seems also the head has been converted to accept SFC 7mm stem valves, or is an original '74 SFC head (only MY of skull and 7mm stems). From what I see in the pics is the exhaust valve head seems to be quite deeply recessed in the combustion chamber, but as long as the geometry at the rocker/valve tip wosrks out OK all should be well. Intake valve seat looks good. See how the seats clean up with some lapping compound and go from there. A seat width of less than 2mm usually ensures a nice, gas-tight seal.
IIRC a '74 SFC head will have a 36mm port, not the double venturi 36-34.5-36mm of big valve SF heads (ie from 36mm at the intake flange carb side down to 34.5mm at the engine side - and mating 34.5 at the port entrance.
And what Piet said about tight flanges - VERY important.
thanks for the replies:
  • Yes the bearings (old and new) are C3
  • There is no marking on the cam(s). The head has ‘74’ stamped into it, which I assume is a date (being SF2). I haven’t measured the valves/ports re diameters tho will have a look.
  • The flanges were very tight to press off. You say to tap them on? I thought they would press back on, with some heat… no?
  • I also thought the valves looked quite recessed. But its not a race bike and all I know about the geometry is the tappet adjusters are not near their ends. I’ll definitely lap them in (just a little).
  • Re the cam bearings being loose in the tunnel - I get the point about movement with heat. That must mean most/all of these bikes have scored tunnels and scraped cams. I guess in means they align well. So I’ll refrain from Loctite. Tho 2 of the old bearings were not a tight fit on (off) the cam.
  • I’ll cut or make 2 new half length keys. I did wonder about reversing the cam sprocket for ‘new’ teeth, as the bolts ‘look’ symmetrical around the key way, and easy to transfer the alignment dot. Yes…. No…. maybe…?
Thanks
The flanges are the interference fit Piet mentions, not just tap on, should need a press. The cam halves can generally tap into the centre sprocket before tightening.
I polish my cams and rocker arm mating surfaces any time they are out to remove any impurities. I had a big problem with the studs blocking the oil channel across the head, with several destroyed cams and rockers as a result, so I always put a bit of L shaped wire down the start of the stud hole to prevent that, cheap peace of mind. Check that the oil holes through the rocker arms are open, they can catch tiny plastic chips from the tensioner wheels.
Copper plate the outside of the bearings with a home plating kit. You will need to mask of the inside etc with wax but it works great for worn housings.
J
Thanks
As Quentin has stated, the bearings should be a firm sliding fit on the cams. Use copper-plating as suggested by Julian or simple Loctite to prevent them from spinning there. The bearing housings in your head look just like all others. You can "check" alignment once the cams are installed, they should spin without the slightest resistance anywhere.
A bit of heat helps when re-fitting the flanges. An old mechanics trick is to coat the surfaces to be pressed with stag tallow to prevent galling/siezing without influencing the interferance fit itself, as can be the case with mineral oils or greases.
Don't turn the sprocket around, you'll be missing the timing mark. Besides, wear is neglible, as on the crank sprocket.
thanks for all your replies - very helpful. i now have a plan. one thing...
I've seen other such references on the forum but I don't really understand this comment, as thought the only thing above the studs was the top cover, and I don't undertsand the oil pathways (I assumed it was misting). could you/someone explain a bit more?
Thanks
Thanks
As I understand it: The wire pushes the stud to one side in the hole, allowing the oil to pass freely past the wire, the L bend stops the wire from falling down the hole. I’ve mulled this over in my sleep, in my car and on the dunny and come to the following conclusion.
While I’m not a mechanic or an engineers arsehole…. the oil is passing the stud through the hole, using a bit of wire doesn’t change the stud size, or hole size. But, allows the oil to pass more freely around the wire (think of it like a spacer)
As it’s a proven technique, why not use it?
Someone may have a picture to better understand it.
You've nailed it Chris. Tippie may elaborate on this himself, but being my bruvva I'll take the liberty. He had absolute hell trouble with his SF2 in early days destroying cams and rockers. Assuming poor metal hardening or whatever he fitted new parts, same thing happened. An old family friend of my mum's was a mate of Phil Irving and he passed Mr Irving's number to Lee, who called him and explained what was happening - without hesitation he said 'you have an oil problem'.
So delving further, when he fitted to top cam cover he noticed that the front-rear distance of the holes was too short and the cover was actually pulling the studs inward and blocking the flow of oil from the feed that comes up the two middle front studs and it wasn't getting into the channel. If you look at the top surface of the head you'll see the channel across the face either side of the cam chain tunnel. The feed hole to the rocker spindles comes off these middle stud holes, so by rights the front two rocker spindles should get oil, but I guess it's possible for it to be restricted. What is certain is that the rear stud feed will be completely blocked, and no oil will flow through and into the cam-rocker interface. On heads with the small oil feed holes drilled between channel and cam box (SF3 definitely) these holes will also be receiving no oil.
A thin piece of L-shaped wire laid into the channel and down into the front and rear stud holes leaves sufficient gap for a healthy flow of oil. Without this you can probably get lucky most of the time and the studs will end up in a position when you torque the head down that doesn't impede flow. We've seen top covers that pull the studs in so tight against the channel that the holes needed to be slightly ovalled to even allow the top cover to go on with these very thin pieces of wire in place.
I'm sure thousands of motors have been assembled without issue, but it's just one of those simple mods that represent very cheap insurance. I think Lee has posted pics somewhere back in time. And if you pull a head off and find ratted cams and rockers, this is highly likely to be the prime suspect.
Thanks Tippie - much easiser to see it. I've just examined the head for the various galleries and this now makes sense to me.
So the one piece of wire (each side) is a simple a U shape that sits in the gallery unsupported, held in place by the cam, cover?
cheers
circling back to this thread. i found this vid that show the use of the u-shaped wires as mentioned above, which may help other noob laverda owners (like me) who are trying to understand this. btw the whole series of vids is helpful for us first timers. also a link to the one about reassembling cams - that part of the job now done so slow progress being made.
You get the gist from his vids. One thing to note is that the holes on the galleries he mentions (he pokes something through to highlight them) didn't appear until the SF3 - they may have been used on SFCs as std (which has the benefit of a 10mm oil pump, vs 6mm for SFs). Personally i don't think the holes add any benefit when iused with a std 6mm oil pump - I drilled mine when i first saw them, thinking it must be a good thing - but I blocked them back up some time later. Prior to the SF3 the only feed to the cams was actually from the stud holes, through the centre of the rocker spindles and out the exit holes in the rockers and onto the cam lobes.
Another small thing - you don't need to get the head that hot to fit the cams - a hair dryer or paint heat gun will do just fine - it only needs to be warm. The camchain sprocket doesn't need heating - it's not even an interference fit onto the cams.
