When buying new springs for both the 5/C and 6/C, the springs with less windings are the best choice, that’s for sure.
Marnix
No, but if you put your old 5/C in a prepared small valve head you will believe in wonder. And all this with SF springsWhat about small valve heads? If I put my old 5C cams in the small valve head will I need 7C springs?
Jim
Agreed, and the good news is that best cam for small valve heads is the 4/S, great cam for big valve heads too!No, but if you put your old 5/C in a prepared small valve head you will believe in wonder. And all this with SF springs
and small valve heads with big valves and 5/C Makes Laverda Great Again.......(and some porting of course)Agreed, and the good news is that best cam for small valve heads is the 4/S, great cam for big valve heads too!
Marnix
Yes, he's been doing that for decades.I have a set of Phil Todd valve springs in my 3c, I bet he does twin-cylinder springs as well.
Specs of springs probably vary, as apparently does lift of cams.I'm confused. I've raced and ridden loads of km with 5C cams and std SFC valve springs fitted. Never had a problem. Never suffered from valve bounce. I know for a fact bro Lee has had 6C cams in his race bike and had them in his modded road SF motor for donkeys years without problem - would haver assumed he had SFC springs not SF (Lee, please explain). I'm fitting Todd springs to the SFQ. Surprised with those that the inner springs actually contact the outer springs - inner springs larger OD than SFC springs.
There's no reason to be confused. 5/C cams go well with stock SF valve springs, that's my own experience and from many others, except Paul apparently.I'm confused. I've raced and ridden loads of km with 5C cams and std SFC valve springs fitted. Never had a problem. Never suffered from valve bounce. I know for a fact bro Lee has had 6C cams in his race bike and had them in his modded road SF motor for donkeys years without problem - would haver assumed he had SFC springs not SF (Lee, please explain). I'm fitting Todd springs to the SFQ. Surprised with those that the inner springs actually contact the outer springs - inner springs larger OD than SFC springs.
You may have larger spring stack height due to valve seats being cut back, giving a safer working clearance.I'm confused. I've raced and ridden loads of km with 5C cams and std SFC valve springs fitted. Never had a problem. Never suffered from valve bounce. I know for a fact bro Lee has had 6C cams in his race bike and had them in his modded road SF motor for donkeys years without problem - would haver assumed he had SFC springs not SF (Lee, please explain). I'm fitting Todd springs to the SFQ. Surprised with those that the inner springs actually contact the outer springs - inner springs larger OD than SFC springs.
It's not following the closing ramp because it's inertia is keeping it going, and binding springs.How can they bind at any time if they measure with clearance static? Sure you can have valve bounce but that is the valve left behind and not following the closing ramp on the cam.
Q from the above and I know nothing about twins, that implies your running dual valve springs. I read years ago you could get factory dual valve springs and cups from triples but very few actually do. At one point Doug Home was inquiring at Stators to buy that kit for his triple. BTW my Todd spings are single type.I'm confused. I've raced and ridden loads of km with 5C cams and std SFC valve springs fitted. Never had a problem. Never suffered from valve bounce. I know for a fact bro Lee has had 6C cams in his race bike and had them in his modded road SF motor for donkeys years without problem - would haver assumed he had SFC springs not SF (Lee, please explain). I'm fitting Todd springs to the SFQ. Surprised with those that the inner springs actually contact the outer springs - inner springs larger OD than SFC springs.
If it's a triple, that's normal, if it's a 750, you're in trouble.Q from the above and I know nothing about twins, that implies your running dual valve springs. I read years ago you could get factory dual valve springs and cups from triples but very few actually do. At one point Doug Home was inquiring at Stators to buy that kit for his triple. BTW my Todd spings are single type.
Well then, my SFC suffered from simple valve bounce rather than binding. The phenomenon disappeared with 5 coil SFC springs which are also higher rated.If that happens there are no consequences. If coil binding occurs before full lift things will be destroyed.
Oh no.Biggest case of thread jacking ever.
