Tippie
- Dr?bak, Norway
After all this time trialing and erroring I myself would swap left for right carb, easy on a twin, so that you are certain you are chasing the correct rabbit.
chrisk said:Here is the conundrum though.
Both O rings good, both springs same length. To get even mixtures at idle, dyno guy had to set mixture screws ...... wait for it....... l/h 3/4 turn from closed. R/h at 2.5 from closed.
WTF is wrong here?
SimonR501 said:Could be a partial blockage on RH pilot?
sfcpiet said:Chris,
I meant to write "idle mixture adjuster". Hope you're not mixing them up with the throttle stop screws.
The type used by Laverda have a taper about 2.5-3mm long. There are however, screws with different tapers available. I had one correct screw, and one with a thinner tip. Idle was lumpy and pick-up lousy. Took the suckers apart about 4 times before I stumbled over the fucking screw...
Vince said:I have heard that its possible to snap the tip of the screw off and it stays there if you bottom them too hard.
Went a searching, as I thought this had been discussed earlier :-\markQLD said:to suit Dellorto PHF 32 ??
most (99%) of the mixture screws, i've unscrewed, have had the short tip (~2.4 mm)
but once in a while, i've unscrewed mixture screws with a long tip (~5.0 mm)
so, i just 'assume' the long tips are incorrect and have been swapped by a dpo.
but, when and for what are the long tips required?
Paddy said:Long tip are exclusive Guzzi
Short tip are Lav and Duc.
Vince said:Have a look at where the needle drops into the carb and check both carbs look the same, Guzzis came with a shrowd there as an anti-pollution thing.If one mix screw is wrong maybe its a carb off a Guzzi, I thought you said they were new carbs?
Dellortoman said:I've never seen a choke plunger without a rubber tip. Never knew such a thing existed.
Not sure what you have in mind for your nice new set of jet drills. Dellorto jets come in a wide range of sizes so you should be able to find what you need from the standard selection.
All you can do with a drill is make the jet bigger, so you can only go richer with that approach. I suppose if you drill a jet out and whatever problem you're trying to fix gets worse, then you know you've gone the wrong way and you need a leaner mixture. Bit of a crude way to do things though, because you've just buggered a perfectly good jet.
Personally, I'd leave the drills in their box. Once you start drilling jets, the size number stamped on the jet will be meaningless, rendering the jet useless for any further tuning work.
chrisk said:Piet
You could well be in the running for a Noddy Badge.
Just measured the length of the IDLE mixture screws: length of taper is 5mm on both. But taper goes: L/H carb 1.00 - 1.27mm R/H carb 0.91 - 1.16mm.
Clearly this explains the variance in turns to get the mixtures even. Remembering, "dyno guy had to set mixture screws ...... wait for it....... l/h 3/4 turn from closed. R/h at 2.5 from closed"
hooksey said:My twin the same Chris..... although not as big a discrepancy, only 3/4 turn diff !
Quite possibly carb orifices/mixture screw taper a little different who knows. :-\
chrisk said:You need a Noddy Badge for that! You can get them on EBay
