1200ts
- USA - Riverside CA
The RGS decided again on Sunday to lock up the fuel cap . No amount of foul language would make the key turn. It was lubricated a couple of hundred miles previously but the fuel washes the oil out. This is not the first time this has happened and I see from other posts I am not the only one to have this happen. Luckily I was able to purchase some WD40 and able to open the cap or I did not have enough fuel to get back home!
So after a lot of searching I have located a fuel resistant grease which I am going to try. It is designed for metal fuel valves on aircraft but I see it is popular with old cars as it stops many types of fuel leaks. Besides a lubricant it is also a sealant.
The disassembled fuel cap parts below.
