Hello everyone.
Revision of 3 cl
I opened and removed the primary transmission because it chatters too much for my liking at idle.
This clicking noise diminishes slightly when disengaging the clutch, but it remains very loud it seems to me.
After opening:
The triplex chain did new ras.
The tensioner same thing.
The bell has little or no rotational play.
No crankshaft sprocket play.
No play anywhere actually.........
Once the clutch nut was removed, I found a circular scratch on the back, certainly caused by the axis of the selection forks, an axis that I moved by pressing on it with my finger.
If I read the RMT correctly, this axle is radially pinned to the housing of the left primary gearbox shaft bearing.
It's not normal for him to move, right?
I remain with my question about this snap......what could possibly snap like that?
I add that with the engine slightly accelerated it disappears.
I also add that while the motorcycle was running, there was no indication of any abnormal noise.
I passed an aluminum circle before dismantling to listen to the engine running, on the imaginary crankshaft/clutch axis.
Listening to the crankshaft, nothing, well not much.
Nothing on the channel.
When reaching the periphery of the bell, the clicking noise becomes much louder, say towards the rivets.
On the primary gearbox axis it becomes smaller.
It starts again harder on the other side of the bell, back towards the rivets.
This difference is very clear.
So? Original bell and its hardened silent blocks?
Fork axis?
Other?
Your opinions are welcome.
Have a nice weekend everyone.
Revision of 3 cl
After opening:
Fork axis?
Other?
