Fitz
- Cheshire UK
Hello all, do we have any exhaust design engineers on board
Following my success in the UK BEARS F3 racing this year (another Laverda winner in the class) I was warned by one the scrutineers at Cadwell about the noise level of my monty, it has passed every meeting in the past two years however he took it upon himself to tell me that it will not pass next season. Don't know if he is just bullshitting me, I doubt that, he is good lad, ex racer type
I run a genuine works Barca exhaust system that I re-packed before the start of the season, it has regularly measured 102dB < 105dB and has raised some eyebrows on occasion, in my opinion it's not noisy and the noise it does make is excellent, I have had loads of people telling me how nice it sounds flat out
I have one that I had made when I first built the bike but it has those boring cylindrical tubes that just look awful, not too bad from the side but from the rear its just but ugly (not unlike myself)
I have tried to read up on "muffler" design but there is more BS stated about this subject by "experts"
Some "informed" opinion suggests that for relatively small engine power and from the period the engine was designed, changes to back pressure and pressure waves will not affect performance too much, a little restriction in the system is unlikely to be a problem as valve overlap (which seems to be key) was not as crucial a design feature as it is with today's modern engines with precise fuel injection exhaust design and valve overlap to match
The opinions vary as people are simply trying to use their interpretation of the science to sell their products
I think that there may be a possibility to introduce some kind of noise deflector into a short extended section between the end of megaphone section and the reverse cone that is riveted on. That way I could retain a good look but reduce the noise
If we have any real smart Alecs I could consider re-designing the baffle tube which is a pretty basic affair, just a perforated tube with two end caps to locate it centrally in the megaphone section
I have put an image of the Barca and version I had made - any ideas
