Hi again,
Is there a special trick to adjusting the steering head bearings on a 750 with factory steering damper?
I loosen the damper, then loosen the bolts on the bottom triple clamp and then tighten the 32mm nut between the top triple clamp and the steering head - all with the wheel off the ground and until I feel slight resistance. Then torque everything to spec.
However, play seems to increase after only a few kilometres.
What am I doing wrong?
Esben
Esben
