Alpino pawl spring issues
corsaro
York UK
Working on on the 500 Alpino today removed the clutch casing and noticed the end of the pawl spring on the gear change had broken off. The design is a rotational spring - which appears to break readily looking at some posts from - well way back in 2022, as there were a couple of pics showing the same breakage....... looks like it could be easily replaced with a tension spring from a simple bracket located to the bearing retainer hex head screw. The 750's as I recall had a tension spring for this duty which is probably more sensible!
just wondered if anyone has carried out a modification in this area.
Stu
