America Eagle / early GT sidestand wanted
I bought one from Wolfgang, but it was the only one he had (sorry, I know that doesn't help!).
By the way, the stand springs that Andy Wagner was selling were a bit 'saggy', unless he's improved the design/spec.
Side stands and centre stands are reasonably simple devices. You can make your own if you have some basic metal working tools - welder, grinder, etc. I've made both from scratch on several occasions when I needed a custom job, or when the factory supplied item is a piece of junk.
If you make one, make sure you thread the inside fixing lug so that the pivot bolt doesn't need a nut behind it. Some replacement ones I have seen these days have a nut behind that the spring fouls on.
