thomas@hauge.net
- Gothenbourg, Sweden
I had trough the years tried several systems and all of them is a major improvement how the engine runs!
Motodd/Boyer:
First aftermarket system I tried . Not adjustable, no rev limiter. Uses stock pick ups. Only downside was that it needed a really fresh battery and starter set up. No spark if rev was to low.
IIS:
I bit more work to fit, more settings to choose from. No issue with starting with not fully charged battery.
Sasche:
Also require some wiring. The pick up plate and rotor is bit "tiny" end not so easy to get in right position. Very much like the IIS when it comes to different curves etc.
Ignitech:
The box looks (together with Boyer) most weather prof of the all. I like when you can adjust everything with a computer. This means you have to know what you are doing (not sure i do all the time), Not sure there is bolt on kits for the laverdas though.
The box only have two inputs which means a 180 can have a one or a two pick up systems when the 120 only can have a one pick up system only.
All systems requires a proper set up with a strobe!
Motodd/Boyer:
IIS:
Sasche:
Ignitech:
