Schurminater said:So.............(Lavflag) the laverda flag is flying after my first ride on a 180 Jota and i love it!.........after the first ride around the block i was amazed at how comfortable the riding position was and how stable she felt,being very top heavy at standstill,on the move she feels firm and planted and ready to rumble......torque from standstill with little to no vibes, awsome and i was pretty amazed how nice it felt.
Issues?....well apart from me concentrating so hard on the right hand gear change,i completely forgot about the back brake and also completely forgot what gear i was in![]()
There needs to be a bit of fine tuning on the clutch and rearset levers,changing up 1-5 is absolutely fine but changing down seems a bit temperamental with me often getting stuck in third gear with the lever not picking up with the selector drum as it were.I know there are lots of postings on this subject already, I may have to have another fiddle with the eccentric bolt?.......any advice welcomed.
So jobs left are the fitting of a bar end mirror which is hopefully on its way,replace a couple of side stand bolts also on their way and then get out and enjoy her...........and in between riding just look at her,what a beaut 8)
Paul LeClair said:I have several motorcycles that I ride regularly, including a couple of Laverda's.
cbertozz said:Just playing catch-up with this thread. Great to see another machine and new owner.
Gearbox was one of my bugbears initially and a quick fiddle with he eccentric did help but mostly it was making sure the clutch cable was properly adjusted. Now it clicks quite neatly into first without a massive clunk.
I still.sometimes find 1st >2nd a bit crunchy if I'm not concentrating, but everything works better when accelerating harder
It also has quite a distinctive thunk from third to second which helps knowing what gear I'm in coming to a rest. Looking forward to getting some rearsets!
Properly setup the bike is amazing considering its age. At legalish speeds in the country it is more than capable of keeping up with modern bikes assuming you have the suspension well set up. I love hooking into a corner with inner thigh locked into the tank. It responds beautifully to cracking the throttle early in a corner and maintaining even the most gradual roll-on. It's brakes are such that I find myself trail-braking.
Anyway now I've tuned in I'm looking forward to hearing more and learning some things along the way as the bunch here have been very generous with their time in helping me get my bike sorted.
mauricejota7604 said:Hi Steve have a quick look at the eccentric adjuster sounds like the fork is unable to travel down far enough , you can lean your bike over a bit to stop the oil leaking out its a 5 minute job to inspect.
But before you try changing too much go riding heaps and heaps big Laverda triples are not like another bike and you need to tune yourself to the bike.
I always find it takes me a couple of tank fulls of fuel (400kms approx) before I am really back in the groove with my Jota.
Pump up those tires and enjoy the nice spring UK weather on her over Easter!!!!!!!!
