Simonr501
- Lympne, Kent. UK
padlock said:who ever actually builds the loom for me will get it down to about three wires.I may be able to understand it then
Nah! That's only Eny, Meeny and Miny!
I could have wired it this way but we wanted the Kill switch to Kill the ignition and disable the starter. I could have wired it up this way using relays but that is defeating the intention of making the wiring simple. If I was needing to Kill the engine (for some reason) on the side of a busy motorway at night I want my lights to keep working so that the tin tops can see me. Maybe this is not a likely scenario but it could happen.Laverdalothar said:Hi Bruce,
you can put the kill-switch between ignition and the M-unit, that would solve your first issue, no?
Yes I looked at that but we are not sure what Tail Light is going to be fitted to the bike yet. Plus I think this still has the same always on logic. You are correct you can use the switchgear to turn it off by a sequence of timed operations but as Cam said this seems like a lot of farting about. There is no desire to change or add more buttons/switches to the handlebars.Laverdalothar said:Also, you can change the setup of the M-Unit to a one-cable-operation mode for the taillight so that brake light and tail light are operated by one single cable from the brake-light-connector of the M-Unit. would solve your second point (you would need a LED taillight though for that as far as I understood the instructions; not sure if you can take any LED taillight or only a special one from motogadget?!?).
I think this exactly the point I was making in my original post Lothar. You are correct, the unit is really aimed at the custom bike world.Laverdalothar said:Cam, disappointment is always a result of a mismatch between expectation and outcome.
The M Unit is NOT designed mainly for usage with old school, classic handle bar switches. It is designed to reduce cabling and weight on the bike as much as possible. It is designed for custom bike scene, not for classic bikes. You can make it work with some limitations on classic bikes with classic switch gears, too, but then you will face some limitations. Why? Because you are not using it for what it is designed. Problem of the product? I don't think so. Look at their homepage and at the manual, you will find that the target market is custom bikes and you also will find the limitations and options listed in the manual.
padlock said:... will be no indicators, no back brake light ...
motoddrob said:So simple that even I could make sense of it.
4 relays plus starter relay.
padlock said:Cam,In the UK a bike registered before April 1986 doesn't require a brake light at all!!! Or indicators.
FFF
padlock said:I've got an m-unit and m-button, motogadget switch gear and motogadget speedo/rev counter to fit to jenny,will be no indicators, no back brake light and no ignition switch, am hoping that who ever actually builds the loom for me will get it down to about three wires.I may be able to understand it then.![]()
FFF
