Anyone I.D. this master cylinder
phil37
Lincolnshire
Hi All - Just been going through a load of Monty spares I got recently and found this goldline master cylinder. - It's stamped 12.7 diameter under the lever mount - the Montys had a PS12 I think. Someone said it's from a Ducati and worth a few bob so I'm keen to know if anyone can tell me what it's off - regards - Phil
Looks like a PS12 with remote. Very rare but i need to look up what it might have been fitted too.
All i can say is the Race TT2 used a PS15 like that. Gold with a remote reservoir when the cockpit was tight. I have not come across a PS12 like that before. Its poss the early TT1 used a pair of PO5 callipers and a PS12 ? rather than the TT2's PO8's with a PS15 ?
Either way its a race bike set up, i dont remember ever seeing that on the road.
Sorry cant help more than that.
Probably wildly off the mark here, but it looks remarkably like the unit that was fitted to the Egli Ducati my brother used to race, was what looked like a standard PS12 with most of the the reservoir chopped off and a homemade cap fitted with the take off to go to the remote.  Looked like it was custom built when he got it as there was bugger all clearance for the original high reservoir.  After a few high speed 'modifications' it eventually ended up with a liner and 6 small cap head screws so it isn't his, but pretty similar...
Bimota DB1 used that type of setup with the remote reservoir conversion, but they were normal black ones and I don't know what size they were.  I'm not sure that ally remote conversion plug in the photo is original brembo, from the sharp edges and lack of anodising I'd guess it's a home brewed one.
I have the same pump but in 15mm I think laying in my Garage. Came off one of the 2 SFC1000 I bought some years ago. I put an original one back on as I wanted to make the bike as original as possible. If anyone is interested, I can verify the diameter, post a pic an you can send me an offer via PN.
cheers
Lothar
Well, no definitive answer I'm afraid, but here's what the TT2 lads have come up with so far.
Roy Thersby
That is a remote resevour adaptor in a brembo master cyclinder, i made them and for other master cyclinders in the 1980's we made both clutch and brake Ducati followed by making them standard on certain bikes
Dean Brown
Thanks for that, Roy. Is it one of yours then or an example of a common mod from the time?
Stephen Hay
looks like it is off a BIMOTA DB1, I have one and the reservoirs for the front brake and clutch are remote from the master, linked by a length of hose
Dean Brown
Great minds think alike Stephen, someone has also suggested a Bimota connection on the Laverda site. "Bimota DB1 used that type of setup with the remote reservoir conversion, but they were normal black ones and I don't know what size they were."
Roy Thersby
Its hatd to say the first ones were just billet plugs tapped and a machine groove placed in the side of the disc to accomidate the sealing o ring the idea was the reservoir caught the tt2 screens and caused a problem adjusting the clipons for different riders. It could be on I made over a 100 of them also for honda and yamaha m/c as brembo hadnt got their sizes correct for different callipers and the jap ones were a ?100 cheaper. To replace if a tumble off occured. I think a charged around a fiver a time for them.
Paddy said:
I'm pretty sure the DB1 used a PS15 ?
Just about any bike fitted with dual P08 calipers would have had either a 14 or 15mm M/C fitted.  The 15 is far more common.
A 12mm M/C would suit dual P05 calipers, as used on Montys, Pantahs and the like.  Guzzis would be the exception with their linked brakes, usually had a 12 or 13 up front for the single disc.
Look what i just came across on e-bay
http://www.ebay.co.uk/itm/Kit-pompa-brembo-Ducati-TT1-TT2-F1-Pantah-/251761895658?pt=Ricambi_e_Accessori_Moto&hash=item3a9e2da8ea
And a complete one
http://www.ebay.co.uk/itm/Brembo-Hand-Bremspumpe-classicracer-Bimota-LAVERDA-Ducati-TT-externer-Beh-/371215274845?pt=Motorrad_Kraftradteile&hash=item566e27935d
Here's another set up with that M/ cylinder on the works Armstrong.
