michipons
- Palma de Mallorca
Hi!
I am mounting the 750 camshaft. After several tries, I reached the conclusion that the "correct" (may be) way to do it was to assembly all together outside, camshaft, bearings and flanges and then introduce them in the cylinder head and screw everything to the timing sprocket. I still don't have 100% clear, how should I position the key. Should I put it in one of the two halves like in the photo? The problem is then, that is difficult to do the same with the other flange, because the key slots get misalign when pressing the flange as it doesn't have a guide (key) to slide in. I have to tap all the parts quite hard as they don't slide easily to make things more complicated, making it impossible to realign the flange to match the key slot in the side that doesn't have it. The key is also very hard to slide, I don't know if it has to be that way or is because is a bit wear and should slide smooth... Anyway, I thing I would manage to assembly everything at the end, but if somebody could tell me if I am doing something wrong before I do something without return....?
I also wanted to change the nuts of the time sprocket, but they are 6mm for a 9mm wrench! The standard 6mm nut is for a 10mm wrench, which does not fit as is impossible to use a ring wrench to torque it properly.. any ideas there? I remember we talked in another topic about changing those nuts and washers, but now I don't see how, I think is not easy to find those non standard nuts...
Regards and thank you for your help as allways!
Miguel.
Miguel.
