I recently started a 30 year 70,000 km service on my '81 180 SII Jota. Early on in the process I discovered some issues concerning the Sachse ZDG3 optical trigger unit I had installed over 2 years ago (~10,000km). As I was going to replace the primary chain I removed the ignition cover and was surprised to find cooked dust inside. After removing the primary cover followed by the Sachse rotor (S/r) from the end of the crank (also called the driver sleeve) I found it had been ground down (~0.2mm) by the spacer that sits between it and the primary cover inner bearing race.
See attached. As most of you will know the bearing race, spacer and the rotor should all be locked tightly together so they spin with the crank. It would appear the S/r did not achieve a sufficient compression to ensure this and therefore allowed the spacer to spin independently of the crank and rotor. I measured the inner bore depth of the S/r which was about 15.2mm. The original Bosch rotor has a depth of 16.5mm, some 1.3mm difference. I contacted Volker Sachse and he replied that he was only aware of one other case of this happening and that was on his own RGS sometime last year. He also said that when he measured the bore depths of other 'drive sleeves' they varied between 16.0mm and 16.5mm. Since then he has increased the nominated bore depth to 17.00mm
So I would suggest that all of you guys and gals out there who have fitted a Sachse ignition to a 180 SII or 120 triple last year or earlier to check under the ignition cover for signs of abnormal heat. If you find some you will need to remove the driver sleeve and check its bore depth is sufficient to clamp hard against the spacer etc. Volker did offer to provide another sleeve to me but I had already managed to repair the original and increase its depth to 16.2mm which seems to work OK.
I hope that it is only Volker and I who have been affected! :
Rod
Rod
