Banging Up & Down shifts under full throttle with a heel toe shifter !
Laverda SF
This was my solution for a 1970 750 SF0 Breganzie Laverda Cafe.
Elegant shifter - There's a lot going on - Rather compact comprizing of threads with compression springs in that peg.
Tony bought my 70 SFO Cafe and made it original but I will not relinquish my rear set cafe shifter designs - There mine.
You may also like my rear Drum Brake shifter for mechanical drum brakes:
The Cafe rear brake lever design for drum brakes is evident but the Cafe Heel Toe Bang shifter is NOT.
Rather simple but my rear sets work - Not saying you should not ease the throttle and feather the clutch when shifting rather then shift banging at full throttle at your risk ;o)
