Bar end weights.
Dellortoman
Paul's mention of handlebar end weights in his Moto Giro Bike thread piqued my interest, so I've been trying to fire up a few rusty old brain cells on vibration theory.
The weight (or rather the mass) of bar end weights is an important consideration when you're trying to control vibration, but very few products on the market actually say what they weigh. They just call them bar end weights and leave it at that. So most of the time you're buying an unknown product. That seems ridiculous to me. It's like going to buy shoes and the salesman not asking what size feet you have. It would be more helpful if they just called them bar end plugs.
If anyone is in the market for bar end weights for vibration control, I'd suggest you stick with the brands that actually state the weight, so you at least have some clue as to whether they'll be effective.
The weights are usually given for the pair, so 500g is 250g on each bar end. Weights up to 500g are easy enough to find on line. There's plenty on eBay for reasonable prices. Weights above 500g are a bit less common. The heaviest weights I've seen so far are 890g/pair labelled Magazi for sale on eBay. They're 4 times the price of most of the others, but they look stylish, which is the most important consideration. :rolleyes:
Knowing what weight you need is a mystery that you can really only solve by experimentation. I haven't actually done any research on the resonance of motorcycle handlebars, but I have worked in the area of vibration and acoustics, so I know it's not something that has a predictable answer. There are too many variables to be able to make any sensible calculation of what weight is required for a specific bike. However, there are a few basic principles that may serve as a guide as to whether to go heavier or lighter than what you've already got.
  • Bar end weights don't actually dampen vibration. They just change the resonant frequency of the bars.
  • A heavier weight will reduce the resonant frequency of the bars. Lower frequencies tend to be less bothersome to the hands.
  • Short handlebars will have a higher resonant frequency than long ones. Clip-on bars will resonate at a higher frequency than full width bars.
  • You could make the vibration worse if the weights bring the bars' resonant frequency into a range that's stimulated by your normal cruising speed/revs.
I couldn't find much info on internet about bar end weight selection so it appears to be a subject that's sadly lacking in research.
I did find one article that sounded like total rubbish. The author was under the impression that bar end weights were there to "balance your handlebars" to make the bike track in straight line. He asserted that if one weight was heavier than the other, then the bike would pull to the heavy side. I thought about asking him why it doesn't pull the other way because of counter-steering, but decided not to stir up an argument. If his theory is true, then bikes with only one mirror are in trouble. Here's the article for anyone who wants a laugh.
The most sensible information I've found so far is a post on the Aprilia forum by a bloke called Bob Walker. I have no idea who Bob Walker is, but he at least seems to have a few brain cells.
Over the years I have tried everything known to man including these gadgets that fit inside the ends of the bar plus I incorporated bar weights on the outside end of the bar and just to show how ANAL I am these Bar Snake blokes make a Liquid that I injected into the sealed centre section of my Laverda Bars after drilling a couple of small holes. I was desperate to stop my hands from losing feeling, especially if I was cruising at or about 4500rpms. Either I fixed it with all that stuff or Reds Crank rebuild reduced the vibs but I now don't have this issue.
Looks like the liquid isn't sold anymore, it was a 2 part silicon like gooey syrup-like stuff that weighed way more than you would have expected.
I can't remember the name now but there was an adjustable bar weight that was a tuned weight inside the handlebar. Made sense for constant rpm's but I don't know if it really was successful.
Same technology is used on helicopters to reduce vibration but it is for a fixed rpm.
Jim
A fat 14mm allen bolt screwed into a length of snugly fitting rubber tubing inside the bars makes an invisible and handy dampening weight. Experimenting with different lengths might even yield the desired result. Worked OK for me on the GTL when it vibrated like a bugger. I was able to remove the excess weight after finally getting to balancing the crank.
My solid alu Maguras worked very nicely at reducing vibes on my 38 and 41mm forks. The alu clipons I am using now are hollow so I might even press in some alu rod so they are effectively sold! Hollow must surely be susceptible to hi frequency vibes more than solid bar?!
Interesting info on bar weights, Cam. I'm sure it's a set weight for every bike and changes with RPM as you say.
I had a pair made by my local gunsmith pal, but they were not for anti vibration, they were to be sure that if the bike drops onto the RHS, that the twist grip will not get punched up the bars and break the quadrant that pulls the cable. experience has shown me that tbis easilly happens, I returned from Sapin four years ago with the throttle having feeling a bit vague, I had tumblesd in a car park, and compounded that by doing the same in Piazza Mazzini (Breganze) Italy the same year (damaging Boothbies Corsa YIKES!) as well, the same year, the vagueness turned out to be as I describe with only about 30 degrees of the flange cable mechanism stil doing any twisting, very close to breaking and that would mean no throttle!, now if it falls, the twistgrip is protected by the bar end.
Rather than making weights out of Aluminium, see if you can get hold of some uranium. That stuff is a lot heavier than lead and the radioactivity will keep your hands warm.
.... you do have a sense of humour 😊
And very clever too, but never known a bike that needed bar weights (but only experienced high speed wobbles a few times).
Question though ... are we talking steering dampers here?
Many years ago i attended an open day at the ANSTO facility at Lucas Heights. Among the exhibits was a bar of U-238, from memory about 15mm diameter and maybe 500mm long. You could lift it to test the weight, it was amazingly heavy for the size (i.e. dense). It was chained in place so that no one could walk off with it in their pocket.
bazzee
