Fitz
- Cheshire UK
I dont suppose we have a VW diesel specialist amongst our brethren
My race van (T5 2.5TDI 5 cylinder job) was getting very hard to start and starting to smoke a little
Having had some work done on an injector previously I knew the cam had seen better days
After the poor starting problem, the guys that look after all of my cars and van told me that it was likely to be seals / o-rings on the injectors causing the starting problem. While it was apart we decided to change the cam and buckets
It started immediately, all went well until the test drive, they got about 2 miles and it stopped, it had performed perfectly but had to be recovered
Since then, the van will not start. They have checked transfer fuel pump, high pressure fuel pump (7bar available) the cam timing was done using the correct special tool, its just as though the injectors wont work, for no apparent reason. It will run if you squirt stuff down the inlet, it just wont put fuel through the injectors
These guys are no mugs, they work on very high end cars normally, Bentleys, Range Rover, Maserati, BMW, Audi etc very highly qualified but they are completely stumped
I need my van back in service and am desperate for ideas from somebody with real knowledge, I tried VW UK and they very nice but did not provide any help other than to suggest taking it to one of their van centres
HELP
HELP
