While stuffing around with the flat battery problem I was,past tense I hope,noticed the foam mat under the battery had collapsed flat.Today I picked up some replacement foam and removed to old stuff.Yep there was as expected some surface rust under the old foam.Its got a couple of coats of Galmet Rust Converter and I am finishing with a couple of coats of Galmet Epoxy.I got the impression while scrapping it it might be made out of Stainless,quite bright finish under the old foam paint and rust.Anyone know? The question is should I hit the new foam with a coat of contact glue to hold it in place,the foam will stand up OK with the glue but I am not keen on making a rust trap in the future.Todays earth shattering decision.Bit sad isn't it.
