The Sock
- London, England
Having had my OEM cables, on my Triple, for way too many years. Forty-one, to be precise, and having suffered the infarction inducing production of copious smoke issuing from below the carburettors, I finally came to realise that wiring, particularly high load wiring, is a service item.
Dampness creeps up inside the plastic sheath and, with the application of current, electrolytic corrosion takes place. This increases the resistance, which increases the heat produced which speeds up the corrosion. The cycle continues, starting becomes more problematic until something, like the above, occurs.
Check your leads? If they're nice and flexible, fine. If they're stiff and resist movement, replace them.
I got my replacements from Alisdair, at sun_motorcycles on Ebay.
Alisdair is a Laverda guy and extremely helpful. He has standard sizes on hand and, if you've changed your battery orientation or size, he can make cables sized to order.
Service is quick and, along with the other wiring fixes on my SF2, his cables now grace my recent acquisition.
