henrywillms
- Canada
Calling all machinist, amateur machinist and would be machinists....The rear brake on my Corsa stuck on last fall, by the time I felt it dragging (long story) and found a place to safely pull off the road it had locked right up. As a result the disk is scored. It looks like I will have enough thickness left to refinish it. It is a floating disk and I have the oversize buttons that are still holding tight. I read on the forum that it is better to have it surface ground than put on a lathe to ensure it runs true. I have a buddy with a large lathe with a large diameter faceplate that we can bolt it to (by removing the disk from the carrier). Would this lathe method achieve satisfactory results or is surface grinding the way to go?
