Big end diameter, 750 and triples?
1200ts
What is the diameter of the connecting rod big end bearing? I need it for both the 750's and triples. I don't have a crank apart to get the measurements and need to see if I have the correct size bore gauge and honing mandrel.
Thanks, but not the answer I was hoping for. I have about 30 different size Sunnen mandrels but not 46 mm or the equivalent inch size! My bore gauges are also smaller and bigger than this. Looks like I need the wife's permission to spend money.
Phil,
The CR1750 mandrel is designed for split rods where the cap and rod have been ground and are now out of round. Probably a good choice for a factory Laverda rod that after years of use and is now a little bit out of round but for a new Carrillo rod that is round, will not produce as good as possible surface finish as other Sunnen mandrels. Now I am wondering, Red, Keith, Piet and others who rebuild cranks...................................... what are you using? For a connecting rod that is perfectly round, the single stone mandrels do hone better.
Phil,
P28-1750WE, single stone mandrel
Red,
Thank you for the reply. The P28-1750WE is exactly what I thought was the best choice for a new rod as it will produce a little bit better surface finish than the two stone CR1750 mandrel Phil is using.
