bobkandren
A week or so ago I posted a message in the Technical forum regarding disassembly of the primary drive on my '82 Jota which had sat, unridden, for about a dozen years. When trying to re-activate the bike, I was unable to disengage the clutch and thought that the clutch plates were locked/glued together from sitting so long. I first contacted Paul LeClair, whom I hadn't spoken to in many years. He gave me great advice as to how to get things apart, which I followed successfully to the point where it was time to remove the clutch drum. That would not budge. The splines on the drum were "glued" to the tips of the friction plates. No heat or tapping with a plastic mallet would help. HTH, from Australia, mentioned that he'd used a piece of bar stock to make a puller, with 2 holes drilled through it. The holes line up with 2 of the threaded holes on the "posts" which face out from the drum and support the cush rubbers. Then, holding the piece of bar stock against the transmission main shaft. he put 2 bolts through the holes and screwed them in to the holes in the posts to pull off the drum. To be able to spread the force more evenly, I used a 5" by 5" by 3/16" piece of steel and drilled 8 holes in it that lined up with the post holes. Also I'm using steel bolts screwed into alloy holes and figured there would be less chance of stripping any threads. Anyway, with some tapping, it worked and sure enough, the clutch plates were well stuck together. I had to pry them apart with a screwdriver. After much wire brushing with solvents, and with new friction plates, I started the reassembly. Getting the drum back on was an awful job as the tips of the friction plates must be PERFECTLY lined up to match the splines on the drum. I cheated by using a fine file to slightly bevel the outer edges of the drum splines. Then with the clutch lever zip tied to the handlebar, with much wiggling, tapping, and cursing, I got the drum on. Next was getting the primary chain on. I'd not removed the crankshaft sprocket during disassembly so getting that chain on was also a challenge. It can be done, though, by first fitting the chain to the crank sprocket, then carefully. levering the clutch sprocket onto the drum. So mission accomplished and I want to thank Paul and HTH for their help. Bob Andren
