I always let capillary effect do almost all the work. With a full reservoir I open up all the bleed nipples (clear hoses into containers) in situ on the bike, and if the m/c doesn't immediately start to empty I give it a few slow pumps to get it to start. When fluid is flowing through all the nipples I close them off one at a time and do the rocking thing with the M/C. Then I check each calliper the usual way opening and closing the bleed nipple with pressure. I has worked for me every time.On the bike for front brakes.
Gravity will help, but two items that can trap air are the master cylinder which typically has the brake line banjo as its highest point. This is not helpful! Also the brake splitter being horizontal can again trap air. Unbolting both items and tapping them helps overcome the issue.
A quick way to chase air out of the system is to operate the m/c lever with only a very small movement , whilst tilting the m/c outlet up/outlet down so that the air makes it's way out of the tiny hole into the reservoir while you are watching. Air will bubble up through the reservoir. This avoids the need for full stroke pumps to chase the air down to the calipers.
I use a large syringe (150ml) you can get them from ebay cheaply, and attach to the bleed nipple and open it, then use a combination of vacuum and brake pedal/lever to push and pull fluid through.Just replaced front seals and pads (brembo P08 callipers) and spent happy hours trying to bleed brakes. Do most people bleed with everything on the bike or on the bench, ie calliper higher than master cylinder Thanks Richard
Lothar's suggestion of allowing the pistons to push inward and then using a wedge to force them back into the calipers gets rid of trapped air, not only at the pistons but in areas where bubbles may be lurking upstream.As you have replaced the seals, I suspect you may still have air trapped behind the pistons. Might be worth removing the calipers and positioning them so that any air can make it's way up the hoses.
Spot on Steve, as usual. Only can add, that after the first ride, it is useful to again remove the master cylinder, because there will always be some trapped bubbles waiting to be released.For the fronts I always find that removing the mc, angling the banjo down and using tiny movement of the lever to vent the air (much as per Rob said above) does the trick. Various tapping of the lines etc to dislodge bubbles might help but the main culprit is usually at the banjo of the MC.
For the rear brake, it always has to be removed from the bike complete and reoriented to get the air out in my experience. It's a pain but in reality the only way due to the high points in the system and the placement of the bleed nipple at the bottom of the caliper when mounted.
A vacuum and/or pressure bleeder can presumably do both in situ and perhaps more quickly but I've never felt the need. Once they're bled the first time, I try to do a yearly flush of fresh fluid through each entire system and if you do that correctly you never get any air in there again so the requirement for a vacuum bleeder is pretty rare.
I tried this on my front brake a few nights ago, not expecting it to work as it seemed too easy. Released cable tie next morning... perfect.Bleed on the bike. Once nearly there, leave it over night with the lever/pedal depressed so as to let the last bubbles filter through the master cylinder. I must have bled 4 or 5 systems last year, no hassle, with or without a bleeding pump.
I does surprise first time around.I tried this on my front brake a few nights ago, not expecting it to work as it seemed too easy. Released cable tie next morning... perfect.
