Giles C
- United Kingdom
Hi everyone,
I recently replaced my 500's head gasket and unfortunately one side has started to smoke.
I've done a plug chop and a compression test and found that the compression is the same both sides, and the plug isn't wet. Do you think the attached video shows oil or fuel coming out the exhaust? Also do you think I can continue to ride the bike this summer or do I need to look at the valve guide and or seal or ring now?
I've also attached a pic of the plugs, before and after a new set.
Everything is stock carb wise, there's a fresh air filter and it's running Sachse electronic ignition.
Thanks for any help.
View attachment 20230422_183016.mp4
