paulincayman
- Cayman Islands
So just getting into the engine ,head off cleaned but not dismantled..bagged up the buckets and shims...all great until I get to the middle inlet valve assy. Bucket and shims look good but the top of the valve stem and one side of the valve spring cap are showing coarse grinding marks, as if the head has been held up against a grinding wheel....these look very fresh or raw and don't look as if the bike has run since this was done as there is no flattening of the grind marks.
Is this a BS way to fix or disguise a sinking valve...
I did check the clearances before pulling the head and they were on or over, nothing under..
Any ideas?
Any ideas?
