I lost an alternator bolt on The Snowy Run and had a fiddle with it today. The existing bolt only goes into the case approx 5mm and the actual hole isn't much deeper. The bolt I have measured at 36mm shank length, its countersunk so that allows it to go in slightly more than a square-headed alan bolt. Having nearly 5mm out past the alternator cover seems a bit short to me. This bolt is a special, it's an alan head that's been turned down to a countersink and a reduced head circumference so it fits well into the cover hole. What's a good length for these bolts? I think I might also buy a plugging tap and clean out the case threaded holes as well.
