- Calgary, Alberta, Canada
Hi all
not my bike, but I have done a lot of work on it for the owner over the years, fitted a WITT ignition, rewired the bike, general maintenance, etc. It is a 1972 Laverda 750 drum brake. HAs a Bosch charging system.
It is not charging. Zero output from the regulator, measured with a multi meter. Has a whopping 10 volts AC coming in to the regulator at 3,500 rpm from the generator. Going to replace the brushes in the generator again "while I am at it", was done several years ago. The Bosch regulator was replaced several years ago, although that actually turned out to be a grounding issue related to a rebuild on to a then freshly powder coated frame, and the grounding issue was resolved.
Is there a solid state regulator replacement available, if so what is it and where can it be purchased?
Any other thoughts or suggestions? A couple of photos of what I am working with. See below. The wiring you see, with heat shrink, is modern high quality wire and is my work from several years ago. I also checked for proper grounds, and for continuity in the various wires, all fine.
