BOSCH headlight 200 mm early 1000 3C
no I have a  74 3C big headlamp pre oil cooler twin disc coming, in exchange for my Guzzi, once my DVLA plate comes through.
Whatever...i still cant help but give the beautiful black chrome exhaust on my Jota , made by Malcolm, a stroke whenever in the garage..😁😁
Good luck with the headlights Malc not that youll need any luck !! They'll be quality and quality always sells 👌
Hi Malcolm,  great idea! (bigthumb)
Did some research on those rare beasts during the resto of my 3C and found out the following, might be helpful:
There actually two versions with different reflectors and lenses
-Domed lens used on the drummers, lens has Bosch number Bosch 1 305 605 100 (LHD, RHD number unknown)
-Flat lens used on the disc brake models (and probably also on late drummers?), lens has Bosch number Bosch 1 305 605 101 and "H4" imprint (LHD, RHD number unknown).
The domed LHD lens seems available on order at your local Bosch dealer http://www.bosch-classic.com/en/internet/bosch_classic/produkte/karosserie/streuscheibe_1/streuscheiben___mit_teaser_rechts_3.html. Will try to get a price tag on it during the next days.  AFAIK available as new parts as well are  chrome bezel (ca. 85 eur) and reflector for the domed lens (ca. 75 eur).
They are rumours that the headlight shell has been in use on firetruck searchlights, but not confirmed so far.
I have never found a flat 1 305 605 101 lens, neither so the matching reflector, rare as a hens teeth I'd think. Bad luck that I missed the lens offered here by Gert. :(
BTW, the seal for the lens is still available at your local Mercedes dealer, but price tag is north of 100 eur. :o
That said, you can put me on the list for a shell, a LHD flat lens and a matching reflector. (cheers)
Regards,
Stefan
Stephan, I have a reflector, rim and a flat H4 lens, the cost me quite a lot but I dont need them.
Actually I have two flat H4 lenses and they have different homologation numbers on the lens.
If you are interested in them contact me.
Is there a part number on the lens reflector seal Stefan? (not that I"m forking out that sort of money, but for future ref) .
