I sometimes do bottom to top pressure bleeding. It's the logical way to do it because it carries any air bubbles upwards, which is the way they want to go. Also, you can crack banjo joints at high points in the system where bubbles might get caught (the banjos on ends of master cylinders on clip-on handlebars are typically the highest point because the bars are angled downwards). Since the system is held under pressure, the bubbles will be pushed out. It's very pleasing to see bubbles come out of a banjo joint until they stop and all you get is clean fluid, but it's by nature a messy business and you need to have plenty of cleaning rags handy to catch the fluid.
There are other potential mess-making situations with pressure bleeding:
Firstly, the threads on the bleed nipples won't hold fluid under pressure when you pump the stuff into the caliper. You need to take them out, put thread tape on them and screw them back in. They may still leak, but not as much as before. I've tried sealing the threads with grease, but it only works for a few seconds until the fluid forces its way past. Maybe a really thick and sticky grease would work.
Secondly you need a tight fitting hose on the barb of the bleed nipple, otherwise it can blow off under pressure and spray a fountain of fluid all over the place. A little hose clamp would help, but I never seem to have one the right size. I have tried twisting wire around the hose, but it's too bloody fiddly and inconvenient. A tight-fitting rubber hose works most of the time.
Thirdly, you need a reliable way to apply a constant pressure that's sufficient to push fluid through the system, but not so much pressure as to cause the problems mentioned above.
For my first attempt at pressure bleeding I used a large syringe, but it required a lot of effort to push the plunger in. Also, you need one hand to hold the syringe and the other hand to push the plunger in, leaving no hand free to open and close the bleed nipple. I reckon the syringe system of injecting fluid could be made to work more easily if it had some kind of jacking system to press the plunger in that could be operated with one hand. Putting the syringe in a mastic gun should work, but I never thought about doing that until after I made system #2 below.
For pressure bleeder #2, I made a sealed canister that held a volume of brake fluid. It had a fluid outlet at the bottom with a ball valve to close it off, and it had a Schrader valve in the lid so I could pump it up with air to force the fluid through the bottom outlet. Checking the canister pressure with a tyre pressure gauge, trial and error revealed about 10 to 15 psi to be ideal. Any more than that and you'd get a fountain coming out of the master cylinder reservoir. But even with that low pressure the feeder hose would sometimes blow off the nipple (gets quite slippery when wet with fluid). That's when the compressed air system really excelled in making a mess. It would hose fluid all over the place until you could either shut off the feed valve or release the air pressure from the canister. But if you could manage to use the pressure canister without getting yourself and the bike covered in fluid, it worked exceedingly well on even the most difficult systems to bleed, such as Guzzi's linked front and rear brakes.
I've since bought a vacuum bleeder which does the job most of the time. It sucks the fluid out of the bleed nipple so you have to make sure the master cylinder reservoir level doesn't drop too low during the process. Being under negative pressure, it eliminates the possibility of pressurised fluid squirting all over the workshop, so it's much cleaner and hardly a drop of fluid is spilled. However, since it sucks the fluid downwards through the braking system against the natural tendency of bubbles to rise, you still can get stubborn bubbles that will hang up somewhere in the system and refuse to travel downwards.
