Exmoor beast
- Minehead,Somerset, ENGLAND OF COURSE
Ok it’s on the Guzz but fundamentally the same braking setup as Lavs - Brembo original equipment.
I was out riding when I came across a road closure so I stopped quickly to do a u turn only to find the back brake has sticking on, it freed off but obviously not right. On the bench it turned out the rear master cylinder was graunchy & sticking momentarily- orderd a PS15 seal/ piston kit. Fitting the kit today I noticed the bleed nipple not flowing correctly- cut a long story short the short hydraulic hose between the master Cylinder &the proportioning valve / rear calliper was full of lumps of rubber that have delaminated from inside the hose.
I have never seen this in the flesh and externally the hoses are not perished, hard or remotely degraded. I have changed the fluid every two years & never used Silicone/ DOT 5 . Obviously a stern letter to Piaggio is in order- the bikes only 32 years old ffs
How old are your hoses? Never seen this on a Japanese bike or a BMW for that matter.
