R
Reggie3cl
Guest
Smoke... yes. Rings, guides or a hole in the piston?
Reggie3cl said:Smoke... yes. Rings, guides or a hole in the piston?![]()
Doc,
There are 2 different rear MC and lever systems for the RGS.
Either 12 or 15mm MCs were fitted, these necessitated different levers, either 39 or 55mm long, part #s 43 311 181 and 43 311 188 respectively. The longer lever is for the larger MC. If these parts get mixed up, your brake will remain simply ballast, no matter how good the condition of individual components!
The levers are the outer ones that are located through the footrest hangers and are actuated by the pedal.
New seals in both caliper and MC and then properly bled can work wonders, my RGS rear brake actually works!
Cosi said:Reggie3cl said:
and a Zane will smoke em all![]()
