Breather pipe 750GTL
levoz
Oxford
I bought a 750 GTL in boxes a few years ago and am only now putting it together.
There's no breather pipe, so I bought a pipe with a 90 degree bend in it off fleabay and it fits fine. However, in the manual the pipe is shown going forwards whereas I assumed it would go back to the air filter box. However there is no obvious receiver plate/box/hole for the pipe to go into the air filter box. The manual appears to show one, but I think the diagram is actually for an sf. Also it's very cramped under the coil/voltage regulator area going backwards. Does anyone have a photo of the under tank area, so I can also see how the choke and throttle cables are routed? One more question ,the GTL forks are 35mm ceriani and the feel is somewhat soggy. Can I put some of these Wirth springs as sold by Stein Dinse or are they only for 38mm SF forks?
Thanks in anticipation of your help.
