and while you are cleaning up the body ready for a new seal kit,with the two allen bolts and the reservoir removed, you will see two holes,one of them is fairly easy to get clean and clear because it is not so small, the other one looks like a drill has only touched it, and made a small countersink, but in the middle of it is a timny hole, and it too must be clear and clean, the only thing that I could find small enough to pick the sh17 out with was a single wire cut from a wire brush, parafin, and wash with water works well, but do dry everything with an air line.Make sure the bore is in operfect condition, it can take a small hone, but not many diy mechanics have one small enough.While you are doing it replace the O ring in the slave cylinder as well (about 20p) and the rubber dust cover if it s perished (very likely) Wolfgang has had remade them so they are available and maybe locally to you.
