stop taking the piss out of Mr Paul Haggis now Jim if you please, he is a (IMHO) very learned and clever engineer who does not give advice unless it is something that he has tried and it works, my ultra heavy pan European has very different fork legs left and right, the left has a mechanical anti dive, which works by braked induced movement of the calliper, the left does not and is totally different, even the oil quantities are different, the left had=s a damper mechanism in the conventional way and the right has it attached to the underside of the top nut, the spindle is nothing very unusual, and there is only a very mild fork brace under the front mudguard, more heavy duty bracket than a brace, and it all works,
poor old Hag, he was only passing on something that he had discovered as good.
