Hi All,
I need a bit of help with selecting bits please.
I have a period 5 race bike up and running and it has a single FRONT Brembo fixed disc and 08 caliper, braided line and a master cylinder which I have measured the piston from.
The piston mid length measures 12.4mm and the seals suggest the bore is probably 13mm.
Problem is the lever travel is close to zero and the feel is very dead. It works ok but I reckon it needs a smaller diameter master cylinder. What size should work best?
It needs to be period.
I just added a new braided cable so if the thread is the same it would be a good thing. I guess Brembo all fit but Japanese won't?
I know there are some pretty clued up people on here who have been on this path before so please fire away.
Next race is the Southern Classic in 6 weeks so I am keen to strike this off the to do list.
Russ
Russ
