Brembo master cylinder rebuild kit part numbers?
1200ts
I have a number of Brembo master cylinder rebuild kits and need to do the front and rear on a 120 but don't know what are the correct part numbers? I had this written down somewhere but no luck. I don't need to rebuild the clutch but think it uses the same 15mm kit as the front brake?
I know the front is 15mm and the rear is 12mm. I just don't want to open all the packages to see what size the kits are. Or if I even have the correct ones?
So I have:
110 2739 20
110 2739 30
110 4090 30
110 3797 20
Just my luck. My master cylinder is 14mm not 15mm. Piston measures 14.25mm
Bottom of casting is stamped 15F2 14
Is this correct for a SFC1000?
Dunno, but Ducati Paddy has the 14mm overhaul kit (if needed ...). I guess you could always try checking the part number of your kit with him, he being a decent kinda guy ...
I talked to Wolfgang and the repair kits for a 14mm master cylinder are no longer available. Brembo shows it as an obsolete part.
He is hoping some may be available in Germany but it will take weeks to get them.
Some model BMW's of the 1980's use the same repair kit but my BMW dealer also says they are not available.
So if you have a triple with a 14mm master cylinder like both my RGS and SFC, the parts situation is not good. Switching to the more common 15mm may be the only option in the future if you want the bike to look factory.
Also Ducati Paddy don't show any 14mm kits on their web site. They have all the other sizes.
