A couple of spacers to get the centres lined up and Bob's your uncle...
Works fine with the stock 15mm M/C. The bike in the pic is fitted with a 16mm Grimeca unit as the original was lost in a minor "mishap"
. Stainless rotors from French Equipment that bolt straight onto the stock disc carriers.
They are not as modern looking as the P4 30/34 4-pots, but overall performance is at least on par. Weight is a slight handicap though, but considering the P30/34s needing an adapter and 2 extra bolts, should turn out quite similar. But you are stuck with the stock disc diameter. Definitely an improvement nevertehless!
