triumphguy
Good morning,
The front discs I am using on my 1978 1200 Jota America are 310 mm items from a Triumph Super III, using adapters I made up myself based on a drawing from Redax (Thank you!). The calipers are 4-pot staggered bore Grimecas I removed from my Triumph Trackmaster when I switched it over to a Hurst Airheart setup.
The friction surface of the rotors has warped enough that they are unusable, and they are too thin (less than 5 mm) to be turned. However, the carrier is in excellent condition and the floating buttons and their mounting points on the carrier are pristine. I have been looking for a source for just the rotor portion. Yoyodyne has listing for just 'friction surface' sounds like what I am looking for but all they can tell me is "These are replacement frictions (Steel part) for the brembo race rotors. These are usually used by the Factory teams. We do not have a drawing."
I can get replacement assemblies from Galfer and EBC for about $300 each but if I can just replace the rotor portion and save some bucks I would rather do that.
As always,
thanks in advance.
Patrick Cherry
Ojai, CA USA
As always,
thanks in advance.
Patrick Cherry
Ojai, CA USA
