Ventodue said:
Well, maybe that's it - a combination of factors. But I would prefer that the tyre manufacturer would work these things thru, not leave it to the individual owner to try and work them out! But maybe I'am asking too much ... :
Point is, they can not do that for each and every bike in the world in combination with suspension differences, load, temperature and other factors varying...
I assume you have the GFK mudguard and you are not using a fork brace, right? It might (!!!!) also have to do with a bit of a flex in the Marzocchi, as the loads to that fairly unsupported area is quite high when cornering.
what also can make an effect is if you are holding the handle bars to tight. this does force the front to go where you think is right, but not where the corner needs it to be
next point why sometimes this effect even lasts, when you increase the pressure: to stiff front fork. if the suspension is adjusted to a to hard level, the tire has to compensate the lack of travel of the fork. This results in a slight "hopping" of the tire, which causes this effect.
so - either to much oil, to strong spring or to heavy oil in the front or you haven't really relaxed the front enough so it is kind of sticky in its travel. I would check this first and adjust the settings of the fork to work perfectly with the load you put on the bike normally (only you up or with tank bag etc.).
to the point of direction for the front tire: the profile would change if you change the direction. The profile is designed this way to help the wheel run more straight. It might wobble if you put it on the wrong way...
