Jimmer
- UK Berkshire/Wiltshire
Is there a list anywhere on here of bulb specs? Both my tail light and sidelight bulbs have gone and I’m wondering about LED replacements
Thnx
Thnx
Hi - thnx yes I did search before I posted but not too much pother than headlight info. Not to worryUse the search function "bulbs" and you may find useful information that may help you.
These are what I have on mine:Is there a list anywhere on here of bulb specs? Both my tail light and sidelight bulbs have gone and I’m wondering about LED replacements
Thnx
Thanks - that’s very helpfulThese are what I have on mine:
LED Headlamp Bulb: Auxito White H4 9003 LED Bulb HS1 Replacement High/Low Beam Motorcycle Headlight 6000K From EBay
Tail/Brake/Number Plate LED: 12V Negative earth Pt.no. LD12ST from http://www.norbsa02.freeuk.com/goffyleds.htm
Indicator Bulbs: LDIND12V from http://www.norbsa02.freeuk.com/
Flasher Unit: Kellermann Micro 1000 LED Flasher Relay R1,Relay,Universal,6 & 12 Volt 123.965 From EBay
I can't remember the Sidelight size off-hand but you might as well get one from Paul Goff at NORBSA
